Extremely easy to use:
Apply in hot sun or cold temps
Wipes on and wipes off very easily
Provides richness glossiness with protection
Gentle paint cleansing and minor filling abilities
It works on hot paint, cold paint, in the sun or in the shade. It will NOT stain trim or leave white residue. It dries almost instantly, so waxing becomes a quick and easy project. If that wasnt enough, Banana Gloss will actually fill and conceal some of your paint swirls. Do you see spider webs when you look at your car in the sun? Try some BG. The improvement will be significant. Banana Gas contains a complex resin that levels the paint while providing protection and durability. There is also a touch of carnauba for added depth. Black paint and other dark colors look like a deep pool of oil and paint with metal flake looks "bass boat thick." There is quite a bit going on here... You get easy application, paint cleaners, no white residue, trim safe, concealing and of course, protection. All that is left is durability. You should see a good 45-60 days on a daily driver, but with a wax this easy, you may not find out. Prima Banana Gloss: Amazingly easy, simply stunning.
