Add To Cart
Skip Navigation Links
Universal Electric Water Pump Kit
Our Price: $ 24.99
Average Rating:
This kit is a simple single relay wiring kit. You can utilize this kit to turn your electric water pump on when the relay receives power from you turning your ignition on.
A Relay and inline Fuse is the only way to properly power your Electric Water Pump. Wiring the pump directly to your factory fuse panel is dangerous.
The 15amp fuses may not be the size you need. You should check  the specifications for your motor to get the required fuse size.
AutoTrix.Net Electric Water Pump Wiring Kit
Reviews
There are no reviews for this product.
You may also be interested in:
15ft 1/2" Loom
$ 4.95
Average Rating:
Powered by dashCommerce
