Quote:
Originally Posted by thirtytwovalve
Alright, so I cut GRD on L3 and connected it (twisted both ends) to the black wire coming from the module and reconnected the GRD coming from L1... still doesn't work. The blue blade wire is still seated in the socket. The blink sequence is still correct for L2 and L3 but L1 still does not light. When the running lights are on, L1 is lit and when the brakes are applied L1 lights. I'll take another picture. Also, I noticed in Step 4 second picture, both blue wires are going to the connector that links up with the two onange/green wires and then the bladed end is coming out of the connector. I did not do this on the passenger side (and it works), so I didnt do it on the drivers side. Should I do that? In your diagram, it doesn't show the blue wires going to the same spot, they go in two different directions so I followed it.
We have updated the product and not that particular install picture yet. Sorry for the confusion but either way, as you know, it will work the same.
If everything is hooked up the same as the working side, the light in question, L1, does light correctly at times, I would agree with the admins statement that the flasher relay is the culprit and they can really do weird things at times.
