Product Info
Ever wonder why the passenger window on your 1993 through 2002 GM Camaro or Firebird F-body is slow? Why does it seem like you are always changing the window motors? Thats because the factory GM wiring is under powering your passenger window lift motor which can lead to premature failure. Waiting and hoping that your passenger window to completely roll up will no longer be a problem after installing the AutoTrix Passenger Window Fix Kit! Our passenger window fix kit comes with everything you need to properly route power from the battery directly to the passenger window lift motor allowing optimum life and performance for your Camaro or Firebird.
The Autotrix passenger window fix kit has easy step-by-step online instructions. This all inclusive kit contains everything you need, plus extras, to complete your install.
Before and After Install Videos
Product Features
- Preventive Maintenance
- Fix and prevent slow rolling motors
- Prolong window motor life
- Easy 1 hour or less install time
- No need to replace your window motor
Product Contents
- Web based detailed graphical instructions
- 2 Automotive relays with connectors
- 28ft D.O.T. Approved GXL Automotive Wire (Red for power, Black for Ground.)
- 2 fuses (In case you blow one)
- 8 butt connectors (2 more than you need, you might drop one.)
- Inline fuse holder (First fuse already in the holder for you.)
- 2 ring connectors (For proper connection to Positive and Negative studs.)
- Product Option: Add a new dorman window lift motor to your order
How it works
The GM factory wiring gauge is insufficient and causes a low voltage to your passenger window lift motor, especially when both windows are operated simultaneously. The low voltage causes your motor brushes to wear prematurely which creates more resistance. This causes the motors internal breaker to trip before the window is completely rolled up, resulting in a inoperative window that is still open!
The AutoTrix Passenger Window Fix Kit provides all of the needed electrical items to route power directly from the battery to the window motor. The kit also comes with easy to read online install instructions which include before and after pictures of every step in the install process.
Why purchase the Passenger Window Fix Kit from AutoTrix?
Some would argue that they can make this kit without the help of AutoTrix. And the answer is yes, you sure can. But at what cost? Our kit contains DOT approved quality materials. Our kit contains extra components. Our kit comes with everything you need in one package delivered to your door with USPS Priority shipping. We promise that you cannot assemble the contents or this kit for less than what we are selling it for. Besides the time it will take you to acquire all of the needed elements. Trust us when we say, this is a bargain.
Will this kit work on my drivers side window?
Yes, the passenger window fix kit can be installed on the drivers side window motor circuit. However our tests have proven that this kit will not improve window motor life on the drivers side.
Tools Needed
- Wire Strippers
- Wire Crimpers
- 10mm Wrench or Socket with Ratchet
- 15mm Wrench or Deep well Socket with Ratchet
- Flat Head Screwdriver
- Phillips Head Screwdriver
- Electrical Tape
This did exactly what it said it would do. My window went from crawling and sometimes tripping out to going up in just a few seconds. Great product!
Good quality item and instructions, delivered quickly and well packaged.
Thank you for your quick service and I will go over the instructions online when I start this project,
Great kit and awesome instructions. Works better than new.
